Define Precision Control
Use the Coordinates Precision Control tool to control the node precision in the Nastran/OptiStruct output decks (GRID) card.
View new features for HyperWorks 2022.1.
Create an assembly structure from a .csv file definition.
Round off the node coordinates (multiple nodes) to the desired precision and update the HyperMesh database.
Use the Nodal Equivalence tool to select the node location to perform direct nodal equivalence instead of running it through either component or element selection.
