llink
View new features for HyperWorks 2022.1.
Use the Connector Browser to view and modify connectors in the current model.
Use the Control Manager to create and edit the various types of controls that will be used later when realizing connectors.
Use the tools in the Create tool set to create connectors, assign controls, and realize.
Use the FE Absorb tools to create connectors from existing mesh that meet specific types of realizations.
View details for different types of realizations.
A list of realization types that can be specified for point connectors.
A list of realization types that can be specified for fastener connectors.
A list of realization types that can be specified for line connectors.
A list of realization types that can be specified for area connectors.
Organize elements into connector groups.
The FE configuration file (feconfig.cfg) is used to define custom welds such as ACM (Area Contact Method) and other special types.
Attachments are an entity to facilitate the ease of joining subsystems.
Abstract information incoming from the CAD hierarchy to robustly create connectors.
