Seatbelt Mesh Generation
Create a seatbelt mesh.
After the wrap around components have been selected and the global belt data have been set up in the seatbeltsystem Entity Editor, you can create the seatbelt mesh.
View new features for HyperWorks 2022.1.
Position a dummy model using the Dummy Browser.
Create and articulate a kinematic mechanism based on FE mesh using the Mechanism Browser.
Use the Seatbelt Browser to create a complete seatbelt system.
Create a complete seatbelt system, with meshed fabric components and solver-related seatbelt features.
Auto-extraction from the FE model allows for a quick recovery of the seatbelt system without having to recreate the seatbelt.
Apply tension to a seatbelt for testing using the tensioning option.
Create solver seatbelt features using Control Points.
Create solver cross-sections on the seatbelt mesh.
Use the Link Dummy Mechanism to update dummy and seat motion.
In this tutorial you will create a seatbelt system and all related solver seatbelt entities.
Use the Barrier Positioner tool to automatically get the impact barrier into position, based on the selected crash regulation.
Use the IP Impact tools to automatically calculate the instrument panel (IP) testing area according to the regulations FMVSS201 and ECE-R21, position the headform impactor, and export ready-to-run solver decks for all the selected impact locations.
The Pedestrian Impact tool automates the vehicle marking, impactors positioning and the export of solver decks with minimal input, therefore reducing the full process lead time.
Use the Safety ribbon to access crash and safety post-processing tools.
