Browsers supply a great deal of view-related functionality by listing the parts of a model in a tabular and/or tree-based
format, and providing controls inside the table that allow you to alter the display of model parts.
Use the Preserve Edges tool to ensure that specific component edges and feature lines do not accidentally get discarded during auto cleanup
or batch meshing.
FE geometry is topology on top of mesh, meaning CAD and mesh exist as a single entity. The purpose of FE geometry
is to add vertices, edges, surfaces, and solids on FE models which have no CAD geometry.
Tools and workflows that are dedicated to rapidly creating new parts for specific use cases, or amending existing
parts. The current capabilities are focused on stiffening parts.
Use the Defeature: Fillets tool
to find and remove both round (convex) and fillet (concave) surfaces.
The Defeature: Fillets tool
allows you to select a round or fillet, and find all that are larger, smaller, or
similar (±5%) in size. In general, it is best to remove small fillets first, then
larger fillets, then rounds. When you get to a point where you cannot remove any
more, it is time to use other modeling tools and strategies to complete the geometry
simplification.
Note: FE geometry is not supported for this
tool.
From the Geometry ribbon, click the Defeature > Fillets tool.
From the guide bar drop-down menu, select whether to
find Rounds, Fillets, or All.
Click Find on the guide bar.
Rounds and fillets in the model are selected and highlighted
red.
Review each selected round/fillet by clicking and on the guide bar.
Optional: On the guide bar, click to define settings used to
find and select rounds/fillets of a specific size.
Optional: Check Use Parasolid to use parasolid geometric kernels
for finding and defeaturing fillets/rounds.
Remove rounds/fillets in the following ways:
Remove all selected rounds/fillets by clicking Remove All on the guide bar.
Remove individual rounds/fillets by left-clicking on a selected
round/fillet.
