HyperWorks
HyperWorks
2022.1
  1. Home
  2. Interface with External Products
  3. HyperView Solver Interfacing
    Supported solvers in HyperView.
  4. Interfacing with ANSYS
    Overview of how the HyperView applications interface with the ANSYS solver.
  5. Complex Results
  • What's New
  • Get Started
  • Video Tutorials
  • Manage Files and Data
  • Sessions and Report Templates
  • Browsers
  • Sketching
  • Geometry
  • FE Geometry
  • Meshing
  • Elements
  • Model Build and Assembly
  • Composites
  • Connectors
  • Morph
  • Skeleton Modeling
  • Design Space
  • Design Explorer
  • Validate
  • Axisymmetry
  • Concept Modeling
  • Crash and Safety
  • Airbag Solutions
  • Aerospace
  • Aeroelasticity
  • Certification
  • Squeak and Rattle Director
  • Panels
  • Results Data
  • Plot Data
  • Multibody Modeling
  • Media Files
  • Tabulate Results
  • Text Files
  • Publishing and Reporting
Index
HyperWorks
2022.1
HyperWorks
  • What's New
    View new features for HyperWorks 2022.1.
  • Get Started
  • Video Tutorials
    • Change Solver Interfaces
      Load a different solver interface in HyperWorks.
    • HyperMesh Solver Interfacing
      Supported solvers in HyperMesh.
    • HyperView Solver Interfacing
      • Solver Results Supported in HyperView
        When you select a model or results file, HyperView automatically detects the file type and selects the proper reader to import the data.
      • Interfacing with Abaqus
        Overview of how the HyperView applications interface with the Abaqus solver.
      • Interfacing with ADAMS
        Overview of how the HyperView applications interface with the ADAMS solver.
      • Interfacing with ADVC
        Overview of how the HyperView applications interface with the ADVC solver.
      • Interfacing with Animator DB
        Overview of how the HyperView applications interface with Animator DB.
      • Interfacing with ANSYS
        • HyperView ANSYS Results Reader
        • Complex Results
        • Using the Contour Panel for ANSYS Results
          HyperView supports ANSYS elemental results (PLESOL) and nodal results (PLNSOL).
        • Using the Tensor Plot Panel for ANSYS Results
        • Midside Node Results for ANSYS Output Files
          HyperView supports midside node results, and calculates midside node results for stress and strain tensors even though result output files do not have midside nodes.
        • Calculating Total Nodal Forces and Moments
          A new script has been added for ANSYS result files, which allows you to extract total summation of nodal force and moments for the nodes of the selected elements.
      • Interfacing with I-DEAS
        Overview of how the HyperView applications interface with the I-DEAS solver.
      • Interfacing with LS-DYNA
        Overview of how the HyperView applications interface with the LS-DYNA solver.
      • Interfacing with LS-NIKE3D
        Overview of how the HyperView applications interface with the LS-NIKE3D solver.
      • Interfacing with MADYMO
        Overview of how the HyperView applications interface with the MADYMO solver.
      • Interfacing with MARC
        Overview of how the HyperView applications interface with the MARC solver.
      • Interfacing with Moldflow
        Overview of how the HyperView applications interface with Moldflow.
      • Interfacing with Nastran
        Overview of how the HyperView applications interface with the Nastran solver.
      • Interfacing with OptiStruct
        Overview of how the HyperView applications interface with the OptiStruct solver.
      • Interfacing with nSOFT
        Overview of the HyperViewnSOFT interface.
      • Interfacing with PAM-CRASH 2G
        Overview of how the HyperView applications interface with the PAM-CRASH 2G solver.
      • Interfacing with Radioss
        Overview of how the HyperView applications interface with the Radioss solver.
      • CFD AcuSolve Reader
        AcuSolve results for steady state, transient and moving/deforming mesh analyses can be imported and post-processed using the AcuSolve Reader (*.log) in HyperView.
      • CFD Ensight Reader
        Load post-processing files using the Load Model panel.
    • HyperGraph Solver Interfacing
      Supported solvers in HyperGraph.
    • MotionView Solver Interfacing
      Solvers and translators supported in MotionView.
  • Browsers
  • Sketching
  • Geometry
  • FE Geometry
  • Meshing
  • Elements
  • Composites
  • Connectors
  • Morph
  • Skeleton Modeling
  • Design Space
  • Design Explorer
  • Validate
  • Axisymmetry
  • Concept Modeling
  • Crash and Safety
  • Airbag Solutions
  • Aerospace
  • Aeroelasticity
  • Certification
  • Panels
  • Results Data
  • Plot Data
  • Media Files
  • Tabulate Results
  • Text Files
View All Altair Simulation Help
HyperWorks
HyperWorks
2022.1
  1. Home
  5. Complex Results
  • What's New
  • Get Started
  • Video Tutorials
  • Browsers
  • Sketching
  • Geometry
  • FE Geometry
  • Meshing
  • Elements
  • Composites
  • Connectors
  • Morph
  • Skeleton Modeling
  • Design Space
  • Design Explorer
  • Validate
  • Axisymmetry
  • Concept Modeling
  • Crash and Safety
  • Airbag Solutions
  • Aerospace
  • Aeroelasticity
  • Certification
  • Panels
  • Results Data
  • Plot Data
  • Media Files
  • Tabulate Results
  • Text Files
Index
Complex Results
For detailed information about complex results, refer to Complex Results.
