Browsers supply a great deal of view-related functionality by listing the parts of a model in a tabular and/or tree-based
format, and providing controls inside the table that allow you to alter the display of model parts.
FE geometry is topology on top of mesh, meaning CAD and mesh exist as a single entity. The purpose of FE geometry
is to add vertices, edges, surfaces, and solids on FE models which have no CAD geometry.
1D mesh that allows accurate testing of connectors, such as bolts, and similar rod-like or bar-like objects that can
be modeled as a simple line for FEA purposes.
Use the CFD 2D Mesh tool to generate hybrid grids containing hexa/penta/tetra elements in the boundary layer and tetra elements in the
core or fare field.
Automatically generate a mesh at the midplane location, directly from the input geometry (components, elements, solids
or surfaces), without first creating a midsurface.
The Rebuild tool streamlines the process of remeshing existing meshes to generate a new mesh with good quality and flow. The rebuild
mesh functionality utilizes the same parameter and criteria files used by BatchMesher to define the quality criteria and relevant mesh parameters. This algorithm saves significant time over the traditional
automesh and quality correction approach.
Adaptive wrap meshing is a useful utility to get a clean, water tight shell mesh out of 2D mesh containing several
intersecting parts and small gaps which do not need to be modeled.
Shrink wrap meshing is a method to create a simplified mesh of a complex model when high-precision models are not
necessary, as is the case for powertrain components during crash analysis.
Loose wrap wraps the selected elements or components, surfaces, or solids with the target element size specified,
and outputs an outer-volume mesh which approximately adheres to the original FE topology.
Tight wrap creates a wrapped surface mesh which adheres as closely as possible to the original FE topology representation,
automatically detecting and following the surface features of the model.
Volume mesh or "solid meshing" uses three-dimensional elements to represent fully 3D objects, such as solid parts
or sheets of material that have enough thickness and surface variety that solid meshing makes more sense than 2D shell
meshing.
Tools and workflows that are dedicated to rapidly creating new parts for specific use cases, or amending existing
parts. The current capabilities are focused on stiffening parts.
target element size specified, and outputs an outer-volume mesh which approximately adheres
A smaller element size generates a shrink wrap mesh that more closely approximates
the original FE representation and adheres to more features; a larger element size
produces a more basic mesh which ignores more features. The loose wrap does not
project the nodes of the shrink wrap mesh to the original mesh, and typically the
shrink wrap mesh will have an offset from the original mesh, again, the offset is
dependent on the target element size used.
Once the shrink wrap meshing process has completed the new elements will be created
in the current component. For every new run of the shrink wrap mesh, both loose and
tight, it may be necessary to create a new component collector if you wish the
elements to be placed in another collector other than the current component
collector.
Comparison of Varying Mesh Sizes (Shell Output)
Figure 1. Original .stl Model
Figure 2. 2mm Mesh
Figure 3. 5mm Mesh
Comparison of Altering the Jacobian Value for Solid Mesh Generation
Within both tight and loose wrap algorithm’s there is an option to generate solid
mesh. This will generate an all Hexa mesh on completion of the shrink wrap. When the
generate solid mesh checkbox is selected it will expose a minimum jacobian input;
this option essentially hexa meshes the part with this element quality criteria
defined. It controls the hexa quality, which is directly linked to the adherence to
the topological features of the original component. The jacobian value must be
between 0 and 1. The nearer the value is to 1, the cruder the output will appear,
the mesh will be more heavily voxelised. When the value is closer to 0, you are
allowing the shrink wrap solid mesh algorithm to smooth and adhere to more features,
while still maintaining the solid mesh minimum jacobian element quality. By default
the minimum jacobian value is 0.3.
Figure 4. Original .stl Model
Figure 5. 2mm Solid Mesh, Jacobian=1.0
Figure 6. 2mm Solid Mesh, Jacobian=0.3
Shrink Wrapping with Feature Recognition
An additional option can be used to manually define features which will be adhered to
during the meshing process. Typically, when using shrink wrap the mesh attempts to
follow features, but has some freedom to break away from original edges of the part.
However, when the features are manually selected within the panel, the resultant
shrink wrap mesh will follow the chosen features. This can be important when
defining a face of a component that may be in contact with other parts, or there may
just be a feature that needs to be recognized and adhered to and cannot be
approximated for whatever reason.
Figure 7. Shrink Wrap with and without Feature Recognition – 2mm
Comparison of using Global and Local Systems for Mesh Orientation
There is also an advanced option to control the mesh orientation. If you have a
non-uniform part and you want to re-orientate the mesh so that it follows the
features of the original component better then you can use this option. By default
the mesh orientation always adheres to the global system, however, you can generate
a local coordinate system and override the default behavior.
In the example below, you can see the original mesh, the default shrink wrap mesh
using the global system, and the new re-orientated mesh using the local coordinate
system.
Figure 8. Original .stl Model
Figure 9. Shrink Wrap Output using Global System. Default shrink wrap mesh using the global system.
Figure 10. Shrink Wrap Output using Local System. Rows of elements in the reoriented mesh run along the tubes
rather than at angles across them.
