Open Entity Views in the Model Browser
Quickly display all entities of a specific type in the Model Browser.
View new features for HyperWorks 2022.1.
Learn the basics of working with browsers.
The Entity Editor enables you to quickly edit entities in a model and correctly setup solver information.
Use the Entity State Browser to set various states for entities in a model.
Use the Demo Browser to quickly access and open demo model files available in the installation.
In the Mask Browser, set the mask/unmask state for entities at the entity configuration level.
Use the Media Browser to search, display, and edit media file data within the current HyperWorks session.
The Model Browser is a central part of HyperWorks that allows you to get an overview, edit, and control the display of all contents of a model.
Pick required entities, including Nodes and Elements, to be shown in the respective browser and further review and edit data with attribute columns.
Append attributes to the browser as columns to facilitate fast and efficient review, editing, sorting, and filtering in an entity view.
Entity views can be undocked to float or docked to the left, right, or bottom docking areas.
Access additional Model Browser options from its right-click context menu.
Use the Plot Browser to search, display, and edit plot data within the current HyperWorks session.
The Reference Browser enables you to quickly understand complex relationships between different entities that constitute the model.
Use the Results Browser to view the results data model structure while providing find, display, and editing control of entities within the current HyperWorks session.
The Solver Browser provides a solver centric view of the model structure in a flat, listed tree structure.
Use the Table Browser to search, display, and edit TableView file data within the current HyperWorks session.
Use the Text Browser to search, display, and edit text file data within the current HyperWorks session.
The Utility menu contains options that allow you to customize the standard interface to include function buttons, radio options, and text that have HyperWorks-supplied and user-defined macros associated with them.
Double-clicking on a first-level entity grouping invokes an entity view displaying all entities of the selected type. In the entity views, append entity attributes, including those which are referenced, as columns and use column filters for fast and efficient review, editing, sorting, and filtering.
The color of geometry and mesh in the modeling window will be changed if the entity type selected has a corresponding color mode.
