FORSIN
The FORSIN function evaluates a Fourier sine series at a specific value .
Arguments
- The independent variable. For example, to specify time as the independent variable, specify as TIME.
- The shift in the Fourier sine series.
- The fundamental frequency of the Fouries series. It is assumed to be specified in radians per unit of unless a D is used after the value.
- The constant bias term.
- The coefficients for the Fourier Sine series.
Definition
<Post_Request
comment = "WM-WDTM-HAVSIN-FORSIN-DIM-ACOS"
id = "3"
type = "EXPRESSION"
expr1 = "NULL"
expr2 = "WM(30102010)"
expr3 = "WDTM(30102010)"
expr4 = "HAVSIN(TIME,1.,0.,4.,1.)"
expr5 = "NULL"
expr6 = "FORSIN(TIME,0.1,6.28,0.1,0.2)"
expr7 = "DIM(TIME,1.0)"
expr8 = "ACOS(COS(TIME))"
