SHF
The SHF function evaluates a simple harmonic function at a specific value .
<Motion_Joint
id = "301001"
type = "EXPRESSION"
val_type = "D"
expr = "SHF(TIME,0,2,2,0,0)"
joint_id = "10003"
joint_type = "R"/>
Arguments
- Any valid expression used as an independent variable for the Simple Harmonic Function (SHF). For example, to use the z-displacement of I marker with respect to the J marker as resolved in the reference frame of the RM marker as the independent variable, specify as DZ({marker_i.idstring}, {marker_j.idstring}, {marker_rm.idstring}).
- The independent variable offset.
- The amplitude of the simple harmonic function.
- The frequency of the simple harmonic function. It is assumed to be specified in radians per unit of the independent variable unless a D is used after the value.
- A phase shift in the simple harmonic function. It is assumed to be in radians unless a D is used after the value.
- The average value of the simple harmonic function.
