MotionSolve Environment Variables
MotionSolve uses environment variables to locate various files. When you invoke MotionSolve from MotionView, Altair Compute Console, or via the Run script, these environment variables are set automatically - you do not need to set them manually. However, if you launch one of the MotionSolve related executables (for example, mbd_d.exe, mspre.exe, msolve.exe, mpost.exe) at the command prompt, you need to first specify one or more of these environment variables.
Required Environment Variables
| Option | Description |
| NUSOL_DLL_DIR | Specifies the path of the MotionSolve
binaries:
[install-path]\hwsolvers\motionsolve\bin\<platform> |
| PATH | Specifies the location of liblmx-altair.dll
required for licensing:
[install-path]\hwsolvers\common\bin\<platform> |
| RADFLEX_PATH | Specifies the path of the MotionSolve
licensing management executable:
| LD_LIBRARY_PATH ( Linux only) | Specifies the path of any libraries that are loaded at runtime, for
example, certain MotionSolve libraries:
[install-path]\hwsolvers\motionsolve\bin\linux64 Also, the MotionSolve licensing management executable: [install-path]\hwsolvers\common\bin\linux64 |
| ALTAIR_LICENSE_PATH | Specifies a valid path for the Altair License File or a valid Altair License Server. This environment variable is not needed when running MotionSolve via the script motionsolve.bat |
| PYTHONHOME | Specifies the location of the Python
home directory in the MotionSolve
installation, required when running simulations (or co-simulation
with MotionSolve) for models that have
Python user subroutines, for
example:
[install-path]\common\python\python<version>\<platform> |
| DOS_DRIVE_$ | Assigns a Windows drive letter to Unix paths. You can then use a Windows-style path, starting with the
drive letter, on Unix/Linux. MotionSolve, while parsing any path, replaces the drive letter and colon ($:) with the content of the respective environment variable. This facilitates using input files (XML, PY) with references to other files (for example, H3D) containing Windows drive letters in Unix. Usage: DOS_DRIVE_$=path $ - Drive letter to be defined (case sensitive). path - Unix path that you want to replace the drive letter with. For example: “DOS_DRIVE_D = /home" changes "D:/users/mbs/workarea" to "/home/users/mbs/workarea". |
Optional Environment Variables
| MATLABROOT | Sets the root directory for a MATLAB installation, which is required for batch co-simulation runs. |
| MS_ADR_MAPPING_FILE | Specifies the ADR translator mapping file. |
| MS_CUSTOM_MAPPING_FILE | Specifies the default custom mapping XML file. |
| MS_H3DFILE_DIR | Enables you to set one or more paths to folders where MotionSolve will search for flexbodies if MotionSolve cannot find the flexbody file from the path located in the model file. Note that in the case where no path is specified in the model file, MotionSolve looks for the flexbody file in the directory where the solver input file resides. |
| MS_USERDLL_DIR | Specifies the list of folders to be searched for the MotionSolve user-written subroutine DLLs/Python scripts. Separate folder names with a semi-colon (;). |
| MS_USERSUBDLL | Specifies the filename for the MotionSolve user-written subroutine DLL file. |
| MS_USERMEX_DIR | Specifies the location where the mapping files
(*.m) reside when using MATLAB user subroutines in MotionSolve. A set of mapping files is provided in the installation at: <altair_root>\hwsolvers\motionsolve\usersub\mex |
| MS_XSD_FILE | Specifies the XML Schema Description file (XSD) path to be written to the MotionSolve XML file. The XSD file can be used by certain XML editors to validate the XML input file and check for syntax errors. |
| MS_XSL_FILE | Specifies the XML Stylesheet Language file (XSL) path to be written to the MotionSolve XML file. The XSL file can be used by internet browsers and certain XML editors to render the XML input file into a tabular format specified in the XSL file. |
| MS_PLT_UNIQUE_TIME | May be set to FIRST, LAST, or ALL to control which outputs are written to the .plt file when multiple outputs occur at the same time. |
| MS_AS_PORT | Specifies an alternate port number for socket communication used in co-simulation between MotionSolve and AcuSolve. If not set, the default port number 94043 is used. |
| MSOLVE_PLT_EXTENSION | Changes the extension of the PLT file. For example: set MSOLVE_PLT_EXTENSION=req |
| PYTHONPATH | Specifies the Python path to select a different version of Python for user subroutines. |
| PYTHONHOME | Specifies the Python home directory to select a different version of Python for user subroutines. |
| COMPOSE_INSTALL_DIR | Sets the root directory for a Compose installation to select a different version of Compose for user subroutines. |
