Force: Beam
Command ElementModifies a beam element.
<Force_Beam
id = "integer"
i_marker_id = "integer"
j_marker_id = "integer"
length = "real"
E = "real"
G = "real"
area = "real"
ixx = "real"
iyy = "real"
izz = "real"
ASY = "real"
ASZ = "real"
cratio = "real"
preload_x = "real"
preload_y = "real"
preload_z = "real"
preload_tx = "real"
preload_ty = "real"
preload_tz = "real"
</Force_Beam>
Attributes
- id
- Element identification number (integer>0). This number is unique among Force_Beam elements and uniquely identifies the element.
- i_marker_id
- Specifies the Reference_Marker at which the force is applied. This is designated as the point of application of the force.
- j_marker_id
- Specifies the Reference_Marker at which the reaction force and moment is applied. This is designated as the point of reaction of the force. The x-axis of j_marker_id defines the neutral axis of the beam. The y- and z-axes should be oriented along the principal axes of the cross section (in other words, area products of inertial are zero).
- length
- Specifies the free length of the beam. This is the distance from the origin of j_marker_id to the origin of i_marker_id.
- E
- Specifies the Young's modulus of the beam material. The beam is assumed to be homogeneous in its material properties. E has to be strictly positive.
- G
- Specifies the modulus of rigidity or the shear modulus of the beam. This is related to the Young's modulus and POISSON's ratio by the formula:
- area
- Specifies the area of the cross-section that is perpendicularly oriented to the neutral axis of the beam. This is assumed to be constant along the length of the beam. area is strictly positive.
- ixx
- Specifies the torsional stiffness shape factor for the cross section.
- iyy, izz
- iyy defines the second moment of inertia of the beam cross sectional area about an axis on the cross section that is parallel to the y-axis of j_marker_id. iyy > 0.
- ASY, ASZ
- ASY specifies the shear area ratio in the z direction for Timoshenko beams. This quantity accounts for shear deflection in the Y direction. It is calculated with the help of an integral.
- cratio
- Defines the damping ratio for the beam. The beam damping matrix is calculated by multiplying the
beam stiffness matrix with the cratio. In other
words:
- [C] = cratio * [K], where C is the damping matrix and K is the stiffness matrix.
- A value of 0.01 (or 1%) is typically used for cratio.
- cratio ≥ 0.
- preload_x, preload_y, preload_z
- Change the preload force in the beam in the X, Y, or Z directions.
- preload_tx, preload_ty, preload_tz
- Change the preload moment in the beam about the X, Y, or Z directions.
<Force_Beam
id = "307017"
length = "57.55867"
E = "200000."
G = "75000."
area = "314.1593"
ixx = "15707.96"
iyy = "7853.982"
izz = "7853.982"
ASY = "0."
ASZ = "0."
cratio = "0.01">
</Force_Beam>
