Joint Initial Velocity: Revolute
Model ElementThe Jointlnitialvel_Rev element defines the initial angular velocity for a revolute joint element.
<JointInitial_Rev
joint_id = "integer"
iv = "real"
</JointInitial_Rev>
Attributes
- joint_id
- The ID of the revolute joint whose initial velocity is being specified.
- iv
- The initial rotational velocity of the revolute joint. The value specified is the rotational velocity of the I marker of the joint relative to the J marker of the joint. The unit is radians per model time unit.
Consider the simple 2-dimensional pendulum shown in the image below.
Figure 1. Specification of Initial Velocity for a Revolute Joint
Assume that the pendulum body (shown in red) is pivoted at the global origin, denoted by point P, by a revolute joint, such that rotation is allowed about the global z-axis. The center-of-mass of the pendulum is at B.
At the start of the simulation, the pendulum is rotating counterclockwise about the global z-axis at 20 radians per second. The initial velocity of the revolute joint may be specified as follows:
<JointInitial_Rev
joint_id = "1"
iv = "20">
</JointInitial_Rev>
- Besides joints, there are two other ways to specify initial velocity in MotionSolve models: using the Motion_Joint or Motion_Marker element and using the Body_Flexible, Body_Rigid, or Body_Point element.
- If there is a conflict among initial conditions specified using these various elements, the following precedence rule is applied: Motion elements override the joint elements which in turn override the body elements.
- The number of initial conditions should not exceed the total
number of degrees of freedom in the model.
- A system with one degree of freedom should have only one velocity initial condition. The constraints apply consistent velocities to the rest of the states in the model.
- A system with zero degrees of freedom should have no velocity initial conditions.
