Parameters: Static Solver
Model ElementDefines the solution control parameters for static and quasi-static analysis, where the parameters control the accuracy of the solution and the method to be used for solution.
See Static and Quasi-Static Simulation for a more detailed description of each algorithm, including their strengths and weaknesses.
See Parameters: Static Solver in the Command Statements section for more information on Format, Attributes, Examples, and Comments.
