Communication between OptiStruct and AcuSolve
OptiStruct and AcuSolve can be run on heterogeneous and remote platforms which are located on the same network domain. The communication between OptiStruct and AcuSolve is via sockets.
To start a coupled simulation between OptiStruct and AcuSolve, one of them should be run first to initiate the communication process, while the other will subsequently connect to the initiated communication process.
Communication Initiation
socket_port
entry of the
EXTERNAL_CODE
block in the AcuSolve
input file (filename.inp). If the machine that OptiStruct is running on is named
machine1, then the EXTERNAL_CODE
will look
like:EXTERNAL_CODE {
communication= socket
socket_initiate= no
socket_host= "machine1"
socket_port= 10000
should be started independently. OptiStruct will wait
for AcuSolve to initiate the socket connection (or
vice-versa). The time that OptiStruct will wait (in
seconds, after pre-processing is complete) is determined by the
WAITTIME field on the FSI Bulk Data Entry
(the default value is 3600 seconds). Similarly, the time (in seconds, after
pre-processing is complete) that AcuSolve will wait
until OptiStruct initiates communication at the socket
is determined by the external_code_wait_time
field in the
Acusim.cnf file (or the -ecwait
run
option).
Figure 1. FSI Initiation when OptiStruct Starts First
Figure 2. No initial handshake
Before the start of the time step loops, basic information about the interface must be exchanged between the two software. First, a number of parameters controlling the interface strategy must be set for both. Second, the physical parameters of the interface must be defined.
Time Steps and Data Exchanges
For AcuSolve, in conjunction to the
EQUATION
command, which specifies the existence of solution
fields in the problem, you must use TIME_SEQUENCE
and
STAGGER
commands to define time stepping and staggering
strategy. The preferred method is to use the AUTO_SOLUTION_STRATEGY
command to have AcuSolve generate the solution strategy
commands. For OptiStruct, the data exchange parameters
are available on the FSI Bulk Data Entry and time stepping data
is specified on the NLPARM, TSTEP, or
TSTEPNL entries (depending upon the type of solution or
data). See the corresponding SFSI or TFSI User Guide pages for more
information.
AUTO_SOLUTION_STRATEGY {
initial_time_increment = 0.001
max_time_steps = 101
min_stagger_iterations= 1
max_stagger_iterations= 20
and
NLPARM | 5 | 40 | 1.0e-3 | 80 | UP | ||||
1.0e-2 | 1.0e-5 | ||||||||
1.0e-1 |
At each time step, solution variables (displacement/pressures for SFSI,
temperature/flux for TFSI) are exchanged between OptiStruct and AcuSolve until
they converge to a certain tolerance. Once convergence is achieved, the analysis
continues on to the next time step. These exchanges are called staggers
in AcuSolve. The minimum number of staggers (called
exchanges in OptiStruct) can be
specified by the min_stagger_iterations
parameter in the AcuSolve
block, this is also influenced by other
AcuSolve run parameters. The minimum number of
exchanges in OptiStruct can be specified by the
MINEX field in the OptiStruct
FSI Bulk Data Entry.
The maximum number of staggers is set by the max_stagger_iterations
AcuSolve run parameters. The maximum number of
MAXEX field in the FSI Bulk Data
Entry.
The maximum or minimum number of exchanges (MAXEX/MINEX) is set in the OptiStruct model. There may be multiple locations within the AcuSolve model, where the maximum/minimum number of staggers are defined. The FSI run will use the lowest maximum number of exchanges/staggers and the highest minimum number of exchanges/staggers out of all available such specified data. Therefore, depending on AcuSolve, each time increment may end within a subset space lesser than or equal to [MINEX,MAXEX].
The solution variable convergence tolerances are used to reduce the number of
exchanges/staggers to that required receive stable and accurate results. This may
significantly reduce run times while generating results. The solution variable
tolerances are specified by the FCNVTOL,
DCNVTOL, TCNVTOL, and
FXCNVTOL fields on the FSI Bulk Data
Entry. If these tolerances are set high, the solution time will be reduced, but
solution accuracy may also be affected. The convergence_tolerance
parameter can also be used to define convergence tolerances in the AcuSolve input data.
