Linear Static |
Hybrid (SMP + DDM) |
- You can use as many DDM processes
-np ) as allowed by available memory,
and the remainder of the cores can be distributed as SMP
(-nt ).
- If multiple subcases with different BCs exist, then
Multi-level DDM will likely be automatically turned ON.
Different BCs will be parallelized.
- Using the PCG solver could show performance benefit in
cases where DDM cannot be run. Refer to SOLVTYP and Solvers for more
information.
Nonlinear Static Analysis |
Hybrid (SMP +DDM) |
(-nt ).
- For multiple nonlinear subcases, if you believe that
solving multiple nonlinear subcases in parallel can
provide more speedup than sequential, then multi-level
DDM can be manually turned on via PARAM,DDMNGRPS,# (refer to Domain Decomposition Method
for certain exceptions).
Nonlinear Transient Analysis |
(-nt ).
- Multi-level DDM is not supported. Therefore,
subcase-based parallelization is not supported.
Normal Modes Analysis using Lanczos (Eigenvalue
Analysis) |
Hybrid (DDM + SMP) |
- Geometric-partitioning via DDM is supported for
Lanczos, and DDM can be used via
-np
for #cores up to the limit enforced by
available memory. The remaining cores can be distributed
via SMP (-nt ).
Normal Modes Analysis using AMSES (Eigenvalue
Analysis) |
Single Modal Space - SMP Multiple Modal Spaces - Hybrid
(DDM + SMP)
- Geometric-partitioning via DDM is not supported for
AMSES.
- If there is only a single modal space, SMP can be used
via
-nt .
- If there are multiple modal spaces, then BC-based
parallelization is supported for AMSES and a hybrid
SMP+DDM can be used.
-np can be set
equal to the number of modal spaces and the remaining
cores can be distributed via SMP (-nt ).
Normal Modes Analysis using AMLS (Eigenvalue
Analysis) |
SMP |
AMLS. Similarly, BC-based parallelization is not
supported either. Therefore, only SMP is
recommended.
Linear Modal Frequency Response Analysis This only
discusses FRF solution part. For Eigenvalue extraction, see
above.
- Modal Frequency Response parallelization depends on two
main parts:
- Eigenvalue extraction
- FRF solution
- The performance depends on which solution is dominant
with regards to the runtime. If the
#modes are high, and
#loading frequencies are low,
eigenvalue extraction can dominate; otherwise, the FRF
solution dominates.
- Eigenvalue extraction has already been covered above.
- For Modal FRF solution using regular factorization, BCs
are solved sequentially and loading frequencies are
parallelized via DDM. Such frequency partitioning via
DDM can speedup the solution.
- For Modal FRF solution using FASTFR, DDM may not be
useful, unless there is a good compensation via higher
eigen-extraction DDM performance.
Linear Modal Transient Response Analysis This only
discusses Transient Energy Equation solution part. For
Eigenvalue extraction, see above.
- Modal Transient Response parallelization depends on two
main parts:
- Transient Response solution
#modes are high, and transient
response solution is quick, eigenvalue extraction can
dominate; otherwise, the transient solution dominates.
- For Modal Transient Response solution, BCs are
parallelized via Multi-level DDM. However, DDM level-2
geometric partitioning is not supported for Transient
solution within each MPI group. Therefore, in such
cases, certain MPI processes within each group may
remain idle.
Linear Direct Transient Analysis |
- For small models, SMP may outperform DDM since BCs are
not parallelized for Linear Direct Transient.
- For larger models, DDM may provide more speedup since
geometric-partitioning is supported.
- The Newmark-Beta time integration method may improve
performance in certain cases.
Linear Direct Frequency Response Analysis |
not parallelized for Linear Direct Frequency
Response.
frequency-splitting is supported and distributed among
different MPI process groups and within each group
geometric-partitioning is performed using MUMPS.
