User-Defined Heat Transfer Properties
- The QVOL and QVOLLIB Bulk Data Entries for the definition of time-dependent and temperature-dependent volumetric heat generation through user-defined external functions, and/or,
- The PCONV and PCONVLIB Bulk Data Entries for the definition of time-dependent and temperature-dependent free-convection coefficient through user-defined external functions.
- The QBDY1 and QBDYLIB Bulk Data Entries for the definition of time-dependent and temperature-dependent uniform heat flux through user-defined external functions.
- The SPCD and SPCDLIB Bulk Data Entries for the definition of time-dependent and temperature-dependent uniform heat flux through user-defined external functions.
The external functions may be written in Fortran or C. The resulting libraries and files should be accessible by OptiStruct regardless of the coding language, provided that consistent function prototyping is respected, and adequate compiling and linking options are used.
Write External Functions
Two Fortran subroutines are available, one is to define user-defined volumetric heat addition and the second is to define user-defined free convection coefficient.
Volumetric Heat Addition Subroutine
subroutine USRQVOL(ldsid,elabl,elset,nsetl,nsets,max_elset_len,
temp,max_temp_len,time,dtime,tbllabel,tblxy,tbllen,max_table_len,
ntables,evol,ethick,ecentroid, qheat,itablest,jtablest,rtablest,idtablest,
itables1,rtables1,ntables1,ltables1,ntablest,ltablest,itablemd,
rtablemd,nitablemd,ntablemd,ltablemd)
| Argument | Type | Input/Output | Description |
ldsid |
Integer | Input | This is the user-defined QVOL Load Set
identification number (User ID). |
elabl |
Character, vector | Input | elabl is the label of the
elset (the identifier). It indicates the
HyperMesh component
name. |
elset |
Integer, vector | Input | The element ID’s in elabl. Internal IDs and
then user-defined IDs following them (only for debugging
purpose). |
nsetl |
Integer, vector | Input | Actual length of each elset |
nsets |
Integer, vector | Input | Total number of elset |
max_elset_len |
Integer, vector | Input | Maximum length of all the elset |
temp |
Double, vector | Input | Temperature calculated at the element centroid. This is based on internal IDs. |
time |
Double, scalar | Input | Current time |
dtime |
Double, scalar | Input | Time step |
tbllabel |
Character, vector | Input | Label of the TABLEG table |
tblxy |
Double, vector | Input | Contains the TABLEG X-Y values |
tbllen |
Integer, vector | Input | Actual length of each TABLEG table |
max_table_len |
Integer, vector | Input | Maximum length of all the TABLEG tables |
ntables |
Integer, vector | Input | Total number of TABLEG tables |
evol |
Double, vector | Input | Element volumes |
ethick |
Double, vector | Input | Element thicknesses |
Double, vector | Input | Element centroid XYZ coordinates |
qheat |
Double, vector | Output | q calculated at the element centroid – the
volume is calculated within the main source code of OptiStruct. qheat is
vector, it will contain the q’s of all heated
elements. |
itablest |
Integer, vector | Input | TABLEST integer data |
itablest(1) |
Integer | Input | Table identification number |
itablest(3) |
Integer | Input | Starting index of jtablest |
itablest(4) |
Integer | Input | Ending index of jtablest |
jtablest |
Integer, vector | Input | Contains the indexes for the TABLEST temperature values and TABLES1 entries. |
rtablest |
Double, vector | Input | TABLEST temperature values |
idtablest |
Integer, vector | Input | TABLEST and TABLES1 entries |
itables1 |
Integer, vector | Input | TABLES1 integer data |
itables1(1) |
itables1(3) |
Integer | Input | Starting index of rtables1 |
itables1(4) |
Integer | Input | Ending index of rtables1 |
rtables1 |
Double, vector | Input | TABLES1 X-Y values |
ntablest |
Integer, vector | Input | Total number of TABLEST tables |
ltablest |
Integer, vector | Input | Total length of each TABLEST table |
ntables1 |
Integer, vector | Input | Total number of TABLES1 tables |
ltables1 |
Integer, vector | Input | Total length of each TABLES1 table |
itablemd |
Integer, vector | Input | TABLEMD Integer data |
rtablemd |
Integer, vector | Input | TABLEMD X-Y values |
nitablemd |
Integer, scalar | Input | Total length of each TABLEMD table |
ntablemd |
Integer, scalar | Input | Total number of each TABLEMD table |
ltablemd |
Integer, scalar | Input | Total length of each RTABLEMD table |
Free-Convection Coefficient Subroutine
subroutine
USERHTC(pconvid,pconlabel,num_pconvlabels,cnvlabl,cnvset,cnvnsetl,
cnvnsets,max_cnvset_len,sidtemp,max_sidtemp_len,time,dtime,tbllabel,
tblxy,tbllen,max_table_len,ntables,xyzcoord,qvol_temperatures,
qvol_element_sets,qvol_element_sets_len,qvol_labels,num_qvol_labels,
max_qvol_sets_len,max_qvol_temp_len,htc,itablest,jtablest,rtablest,idtablest,
itables1,rtables1,ntables1,ltables1,ntablest,ltablest,itablemd,rtablemd,nitablemd,
ntablemd,ltablemd)
pconvid |
Integer | Input | Convection property identification number |
pconlabel |
Character | Input | Convection property identification label. This is the HyperMath property name. |
num_pconvlabels |
Integer, vector | Input | Number of pconlabels. |
cnvlabl |
Character, vector | Input | Label of the cnvset (the identifier). This
is the HyperMath component
name. |
cnvset |
Integer, vector | Input | Element ID’s and their side in cnvlabl.
Internal element IDs defined on the CONV
entry and then user element IDs to follow. |
cnvnsetl |
Integer, vector | Input | Actual length of each cnvset |
cnvnsets |
Integer, vector | Input | Total number of cnvset |
max_cnvset_len |
Integer, vector | Input | Maximum length of all the cnvset |
sidtemp |
Double, vector | Input | Temperature calculated at the element side centroid |
time |
dtime |
tbllabel |
tblxy |
Double, vector | Input | Contains the TABLEG table X-Y values |
tbllen |
max_table_len |
ntables |
xyzcoord |
Double, vector | Input | Element’s side centroid nodal co-ordinates |
qvol_temperatures |
Integer, vector | Input | Temperatures calculated at the element centroid associated with a QVOL Bulk Data Entry. |
qvol_element_sets |
Integer, vector | Input | Element IDs in QVOL labels |
qvol_element_sets_len |
Character, vector | Input | Actual length of each QVOL element set |
qvol_labels |
Integer, vector | Input | Label of the QVOL element set |
num_qvol_labels |
Character, vector | Input | Total number of QVOL labels |
max_qvol_sets_len |
Integer, vector | Input | Maximum length of all QVOL element sets |
max_qvol_temp_len |
Integer, vector | Input | Maximum length of all QVOL temperatures |
htc |
Double, vector | Output | Convection Heat Transfer Coefficient calculated at the side centroid |
itablest |
itablest(1) |
itablest(3) |
itablest(4) |
jtablest |
rtablest |
idtablest |
itables1 |
itables1(1) |
itables1(3) |
itables1(4) |
rtables1 |
ntablest |
ltablest |
ntables1 |
ltables1 |
Heat Flux Subroutine
subroutine
USERQBDY1(ldsid,elabl,elset,nsetl,nsets,max_elset_len,temp,max_temp_len,
time,dtime,tbllabel,tblxy,tbllen,max_table_len,ntables,areas,thicknesses,
xyzcoords,qbdy1,itablest,jtablest,rtablest,idtablest,itables1,rtables1,
ntables1,ltables1,ntablest,ltablest,itablemd,rtablemd,nitablemd,ntablemd,
ltablemd)
ldsid |
Integer | Input | This is the user-defined QBDY1 Load Set Identification number (User ID). |
elabl |
HyperMesh component name.
elset |
purpose). |
nsetl |
nsets |
max_elset_len |
temp |
time |
dtime |
tbllabel |
tblxy |
tbllen |
max_table_len |
ntables |
areas |
Double, vector | Input | Element area |
thicknesses |
xyzcoords |
Double, vector | Input | Element centroid nodal coordinates. |
qbdy1 |
-qbdy1 is a vector, it will contain the
q’s of all heated elements. |
itablest |
itablest(1) |
itablest(3) |
itablest(4) |
jtablest |
Integer, vector | Input | Contains the indexes for the TABLEST temperature values and TABLES1 entries |
rtablest |
idtablest |
Integer, vector | Input | The TABLEST and TABLES1 entries |
itables1 |
Integer, vector | Input | The TABLES1 integer data |
itables1(1) |
itables1(3) |
itables1(4) |
rtables1 |
ntablest |
ltablest |
ntables1 |
ltables1 |
itablemd |
rtablemd |
Double, vector | Input | TABLEMD X-Y values |
nitablemd |
ntablemd |
Integer, scalar | Input | Total number of TABLEMD tables |
ltablemd |
SPCD Temperature Subroutine
subroutine
USERSENSOR(ldsid,nlabl,ndset,ndsetl,cntrlset,cntrlsetl,ndsets,max_ndset_len,
max_cntrlset_len,tempn,max_tempn_len,max_tempinf_len,time,dtime,tbllabel,tblxy,
tbllen,max_table_len,ntables,tempinf,itablest,jtablest,rtablest,idtablest,itables1,
rtables1,ntables1,ltables1,ntablest,ltablest,itablemd,rtablemd,nitablemd,ntablemd,
ltablemd)
ldsid |
Integer | Input | SPCD load set ID (user-defined SPCD ID) |
nlabl |
Character, Vector | Input | Label of the NDSET (identifier). This is the HyperMesh node SET label (for ambient node). |
ndset |
Integer, vector | Input | Node ID’s in nlabl. It contains the internal
IDs and then the user IDs follow. |
ndsetl |
Integer, vector | Input | Actual length of each ndset |
ndsets |
Integer, vector | Input | Total number of ndset |
max_ndset_len |
Integer, vector | Input | Maximum length of all the ndset |
cntrlset |
Integer, vector | Input | Control node IDs. These are internal IDs and then user-defined IDs to follow. |
cntrlsetl |
Integer, vector | Input | Actual length of each cntrlset. |
cntrlsets |
Integer, vector | Input | Total number of cntrlset. |
max_cntrlset_len |
Integer, vector | Input | Maximum length of all the cntrlset
tempn |
Double, vector | Input | Calculated nodal temperature. |
tempinf |
Double, vector | Output | Ambient Temperatures at the control nodes. |
time |
dtime |
tbllabel |
tblxy |
tbllen |
max_table_len |
ntables |
itablest |
itablest(1) |
itablest(3) |
itablest(4) |
jtablest |
rtablest |
idtablest |
itables1 |
itables1(1) |
itables1(3) |
itables1(4) |
rtables1 |
ntablest |
ltablest |
ntables1 |
ltables1 |
itablemd |
Integer, vector | Input | TABLEMD integer data. |
rtablemd |
nitablemd |
Integer, scalar | Input | Total length of each TABLEMD table. |
ntablemd |
Integer, scalar | Input | Total number of TABLEMD tables. |
ltablemd |
Integer, scalar | Input | Total length of each RTABLEMD table. |
Build External Libraries for User-Defined Materials
You can build shared libraries on Windows or Linux. Refer to Build External Libraries for more information.
