*CONTACT_AUTOMATIC_SINGLE_SURFACE
LS-DYNA Input Interface KeywordDefine automatic single contact interface between elements.
(1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
*CONTACT_AUTOMATIC_SINGLE_SURFACE_{OPTION3} |
inter_ID | Title |
SSID | SSTYP | ||||||
FS | FD | DC | Tstart | Tstop | |||
SFS | SST | SFTS | FSF |
SOFT |
Definition
OPTION3 |
inter_ID | Contact interface identifier. (Integer) |
Title | Contact interface title. (Character, maximum 70 characters) |
SSID | Set or part identifier. (Integer) |
SSTYP | Input set type.
(Integer) |
FS | Static friction coefficient. (Real) |
FD | Dynamic friction coefficient. (Real) |
DC | Exponential decay coefficient. | |
Tstart | Start time. (Real) |
Tstop | Stop time. Default = 1E+30 (Real) |
SST | Stiffness scale factor. (Real) |
SFS | Maximum gap value. (Real) |
SFTS | Contact gap scale. (Real) |
FSF | Coulomb friction coefficient scale factor. | |
SOFT | Contact stiffness definition flag.
(Integer) |
- This keyword maps to /INTER/TYPE25.
