*MAT_018 (POWER_LAW_PLASTICITY)
LS-DYNA Input Interface KeywordThis model expresses isotropic plasticity model with rate effects which uses a power law hardening.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *MAT_018 or *MAT_POWER_LAW_PLASTICITY | |||||||
| mat_ID | E | v | K | N | c | p | |
| SIGY | VP | ||||||
Definition
| mat_ID | Material identifier. (Integer) |
| Initial density. (Real) |
| E | Young’s modulus. (Real) |
| v | Poisson’s ratio. (Real) |
| K | Yield stress. (Real) |
| N | Plasticity hardening exponent. Default = 1.0 (Real) |
| c | Strain rate coefficient.
(Real) |
| p | Strain rate exponent. Default = 1.0 (Real) |
| SIGY | Optional yield stress value. (Real) |
| VP | Formulation for rate effects:
(Integer) |
| Plasticity maximum stress. Default = 1030 (Real) |
- This keyword maps to /MAT/LAW44 (COWPER) + /FAIL/JOHNSON.
- The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
