*RIGIDWALL_PLANAR
LS-DYNA Input Interface KeywordThis keyword defines a planar rigid wall kinematic condition.
(1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
*RIGIDWALL_PLANAR_{OPTION}_{OPTION}_{OPTION} |
ID |
NSID | NSEDX | Dsearch | |||||
XT | YT | ZT | XH | YH | ZH | FRIC |
XHEV | YHEV | ZHEV | LENL | LENM |
Mass | V0 |
Definition
OPTION | Rigid wall type.
NSID | Secondary node to the rigid wall. | |
NSEDX | Secondary nodes excluded from rigid wall. | |
Dsearch | Search distance, used when NSID =
0. Dsearch = 1e20 Default used when secondary nodal set is not specified. (Real) |
XT, YT, ZT | Coordinates of tail of rigid wall normal
vector. (Real) |
XH, YH, ZH | Coordinates of head of rigid wall normal
vector. (Real) |
XHEV, YHEV, ZHEV | Coordinates of edge of rigid wall
vector. (Real) |
LENL, LENM | Size of the finite rigid wall. | |
Mass | Mass of rigid wall. | |
V0 | Initial velocity of rigid wall. In case Mass = 0 this is imposed velocity. |
- This keyword maps to /RWALL or RWALL/PARAL.
