*DEFINE_TABLE
LS-DYNA Input Interface KeywordDefines a table.
(1) (2) (3) (4) (5) (6) (7) (8)
*DEFINE_TABLE
table_ID
A1
A2
An
Definition
table_ID Curve identifier.
(Integer)
An Value that corresponds to the following nth *DEFINE_CURVE keyword.
(Real)
  1. This keyword maps to /TABLE/1.
  2. The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
