/IMPL/DYNA/1
Engine Keyword Describes the implicit dynamics with α-HHT method.
/IMPL/DYNA/1
α
α | Implicit dynamic with
α (HHT method). (-1/3 < α < 0) α =0 set to -0.05 |
- The nonlinear parameters, rather than default values can be defined in /IMPL/NONLIN/N.
- An α-HHT method is the default implicit dynamic method, if /1 is omitted.
