/IMPL/DYNA/2
Engine Keyword Describes the implicit dynamics with a general Newmark method.
/IMPL/DYNA/2
Implicit dynamic with
general Newmark method. (-2 ≤ ≤ 1/2) , =0 set to =1/2; =1/4. |
- The nonlinear parameters, rather than default values can be defined in /IMPL/NONLIN/N.
- An α-HHT method is the default implicit dynamic method, if /2 is omitted.
