/IMPL/SBCS/MSGLV
Engine Keyword Describes the message level for BCS (Boeing) solver.
/IMPL/SBCS/MSGLV/n
n
= 0 (Default)
No printed messages, except the primary messages generated by standard error handler.
= 1
Produces a small amount of runtime statistics and any detailed error messages.
= 2
Creates a more complete set of runtime statistics and a log of steps in the process.
= 3
Produces diagnostic output, including output of the content of various arrays whose length is no larger than the number of equations.
≥ 4
Will produce volumes of output for debugging purposes.
  1. A setting greater than 2, produces debugging output and is not recommended for general use.
