/INISHE/ORTHO or /INISH3/ORTHO
Block Format Keyword Describes the initialization of orthotropy direction for shells element per element.
/INISHE/ORTHO/unit_ID or /INISH3/ORTHO/unit_ID | |||||||||
shell_ID | nb_integr | prop_type | Vx | Vy | Vz |
unit_ID | Unit Identifier (Integer, maximum 10 digits) |
shell_ID | Element
identifier (Integer) |
nb_integr | Integration point number
through the thickness Must be equal to the number of integration points given in the shell property. (Integer) |
prop_type | Property element
type (Integer) |
Vx | X component of the
reference vector (Real) |
Vy | Y component of the
Vz | Z component of the
Angle for first axis of
orthotropy (Real) |
Angle between first and
second axis of anisothropy (for property /PROP/TYPE16 (SH_FABR) only) (Real) |
- This option can be used to initialize the orthotropy direction for shells element per element. By default, property defined characteristics are used, those defined using this option are priority.
- The projection of the reference vector on the shell surface defines a reference direction for orthotropy axis.
- For each layer (integration point), the first orthotropy axis is defined at a given angle from the reference direction.
- This option is compatible only with the orthotropic shell property like /PROP/TYPE9 (SH_ORTH), /PROP/TYPE10 (SH_COMP), /PROP/TYPE11 (SH_SANDW) and /PROP/TYPE16 (SH_FABR).
- For Element of property /PROP/SH_ORTH (/PROP/TYPE9), only one orthotropy direction has to be defined.
