/UPWIND (Obsolete)
Block Format Keyword Describes the upwind coefficient.
| /UPWIND | |||||||||
| Upwind coefficient on ALE
momentum transport Default = 1.0 (Real) |
other ALE transports (mass, energy) Default = 1.0 (Real) |
| Upwind coefficient for wet
area Default = 1.0 (Real) |
- This option can be used for ALE or Eulerian cases (momentum upwind formulation can be reset by using /UPWM options during restart: refer to the Engine Input).
- is a coefficient for multi-phase law. is only available for /MAT/LAW51 (MULTIMAT).
