2022.1
PollEx DFM is a board level manufacturability checking software.
View new features for PollEx 2022.1.
Discover PollEx functionality with interactive tutorials.
PollEx DFA is an assembly status checking toolset for PCB design based on 3D package library.
PollEx DFE+ is a fully automated SI analysis tool.
From the menu bar, click Option > DFM > DFM Input after reading the design file to make a DFM input file.
Check the clearance for an area affected by ground wall.
Calculate and display the number of placed components.
Verify the specified components placement on the board.
Define components that must be placed on a specified side of the board and locate components violating specifications.
Manage the angle of the component for efficient mounting.
Verify the placement of a specified board mark. For example, a lead-free mark, fuse mark, and so on
Analyze the location and orientation of a specified component on the board.
Verify if components are viable for reverse placement on the same board layer.
Segment specified board areas to exclude selected objects. For example, objects such as a via, pattern, solder mask, and so on.
Analyze the board and locate components that are no longer available for use.
Compare the part lists between the standard part library and the used components from the design.
Verify if the clearance between test points and other objects follow specifications and if the test points contain text.
Analyze the clearance between a test point and each component on a board.
Find and examine underfill areas in BGA-type components.
Lock the DFM input rule file (*.DFMI) to prevent any modifications from others.
PollEx Logic DFE is a toolset that checks electrical validity and standardizing of schematic design.
Definition for meta character using in making sentence for searching option.
