2022.1
PollEx DFM is a board level manufacturability checking software.
View new features for PollEx 2022.1.
Discover PollEx functionality with interactive tutorials.
PollEx DFA is an assembly status checking toolset for PCB design based on 3D package library.
PollEx DFE+ is a fully automated SI analysis tool.
From the menu bar, click Option > DFM > DFM Input after reading the design file to make a DFM input file.
Check the clearance for an area affected by ground wall.
Verify the board outline matches the board.
Analyze the DFX or IGES format designs to compare hole locations with the PCB layout design.
Analyze the DFX or IGES format design to compare the pad locations with the mechanical design and the PCB layout design.
Verify matching pin numbers with DXF or IGES data, which inputs as a board layer on PCB data.
Analyze the mounting position of the component, and verify the size of the placement mark.
Analyze the board to prevent damage.
Analyze differences in the special silkscreen and the mechanical guide from DXF or IGES data.
Verify if the clearance between test points and other objects follow specifications and if the test points contain text.
Analyze the clearance between a test point and each component on a board.
Find and examine underfill areas in BGA-type components.
Lock the DFM input rule file (*.DFMI) to prevent any modifications from others.
PollEx Logic DFE is a toolset that checks electrical validity and standardizing of schematic design.
Definition for meta character using in making sentence for searching option.
