SR (Solder Resistor) is a material which is applied to specific areas of the printed circuit board during a soldering
process and protect the circuit of the unnecessary portions of solder.
PSR Covered Via
Check Vias are covered with PSR or solder mask.
Silk on Pad
Check if silkscreen data are overlapped with pads.
Solder Resist Pad
SR (Solder Resistor) is a material which is applied to specific areas of the printed circuit board during a soldering process and protect the circuit of the unnecessary portions of solder.
Teardrop
Check rule related to teardrop in design.
Thermal Pad
Check rule for component thermal pads.
Via Annular Ring
Check the annular ring, the distance between pad and HOLE size.
Via Overstack
Check the number of layers for drilling operation.
Via Spacing
Depending on Via type, check different clearance to different PCB objects.
Via Spacing 2
Check via clearance depending on Via size.
Via S/R Spacing
Check the distance between solder mask in Via to other pads
Wave Mark
Check wave mark in FPC component's edge.
