Check the annular ring, the distance between pad and HOLE size.
Target Layer Definition: Define target layer.
All Layers: All layers including inner layers will be target
layers.
Top and Bottom: Top and bottom layers will be target layers.
Checking
Item: Specify the item name.
Minimum Hole Size: Set the target Vias minimum HOLE size.
Maximum Hole Size: Set the target Vias maximum HOLE size.
Check Type: You can define checking type between Thickness and
Ratio.
Thickness: Use target Vias annual rings minimum size in
checking.
Ratio: Use target Vias minimum annular ring ratio in
checking.
Value: Set the target thickness or ratio value of annual ring.
Remainder: For Vias, not defined, you can check as following option
conditions.
Minimum Annual Ring Thickness: Set the target Vias annual rings
minimum size in checking.
Minimum Size Ratio (Thickness x 100 / Pad): Set the target Vias
minimum annular ring ratio in checking.
Except Via without PAD on same layer: Option to exclude a via without
the Pad is placed on a component Pad from checking.
