Publish a Global Application Definition
Publish a local application definition that is shared by the user as a global application definition.
Users must publish the local application definition to the administrator to make it as a global application definition and accessible to all the users.
- View an application definition
- Edit an application definition
Once the application definition is published to all the user, then it becomes a global app def and it will be stored at PA_HOME/data/pas/targets/localhost/repository/applications/ in the JSON format.
