Monitor the status of your jobs, filter the job view, view job details, monitor memory and core utilization, view
a list of job files, or perform job actions.
Publish a local application definition to the administrator to make it as a global
application definition.
The application definition created using the app composer is a local application
definition stored in your home directory. The application definitions are stored at
/home/$USER/userapps and they are in the JSON
format.
The local application definition created can be made available to all
the users of Access Web by making a global application.
You must
publish your local application definition to the administrator. The administrator will
review the application definition and publish it all the users making it a global
Click .
Select App Composer.
The Applications panel lists all the application definitions that you
have created.
Figure 1. App Composer
Select the application definition that you want to publish.
Figure 2. Select Application Definition
The application definition parameters are displayed in the Compose
panel.
Figure 3. Application Definitions - Compose Panel
Review the application definition and edit the application definition
if required before publishing the application definition.
Click Publish.
Figure 4. Publish Application Definitions
Publish Application dialog box is displayed.
Figure 5. Publish Application
Click Yes.
The application definition will be published to the administrator and a
notification will be displayed.
The app composer application list of the administrator will get updated
with the application definition.
Figure 6. Applications List
Note: The administrator can click to view the user who has requested to publish
