View Job Information
View the job information as provided by the PAS.
The Job information is provided in the following tabs:
  • Summary Tab - View job metadata, view job result files using the text, plot and image viewer.
  • Input Tab - View the input files that are provided for the job.
  • Output Tab - View the job result files that are generated after the job is completed.
  • Running Folder Tab - View the files of a running job.
  • Details Tab - View the job properties information like Job ID, Job Name, CPUs requested, Application, CPU percent used, and Memory used.
  • Diagnostics Tab - View the job diagnostics information which helps you to troubleshoot the issues.
  • Console Tab - This tab is displayed only when Custom Actions are performed on the job.
