Refine Job Monitoring Selection Criteria
Refine your job monitoring criteria by displaying all job or only a subset of the jobs.
Once you have submitted a job to a HPC Cluster, you will want to monitor the job for queuing, execution, and completion. By default, it displays the jobs that you have submitted.
The jobs displayed can be refined using the Filter option. This allows you to display subsets of job monitoring results such as: all jobs that are queued on a particular server or all jobs in a running state. These categories are not mutually exclusive, so you may refine your selection criteria by choosing selection criteria across several categories.
All categories can be expanded providing additional selection criteria to further
refine your job monitoring display results. To expand the category, click the Expand
button
next to the
category. To collapse the category, click the Collapse button
The job list displays only batch and array jobs. To view remote desktops job, select Interactive Jobs job type filter from the left pane.
