LS iron losses computation on point
Introduction
Iron losses computation on point with LS model defined in the material enables to compute LS iron losses on a point belonging to a laminated region. Iron losses model must be defined in the material. The computation gives instantaneous losses volume densities and averaged losses volume densities over a period for a set of fixed geometric parameters or I/O parameters.
This command is the only one that enables to have B(t) and H(t) on a time period, and to plot an hysteresis cycle.
Contents
