Iron losses multiparametric computation
Introduction
Iron losses multiparametric computation enables to compute modified Bertotti iron losses or LS iron losses on a selection of laminated regions. The iron losses model can be defined on the material or in the iron losses computation box in post-processing. The computation gives instantaneous losses for several sets of geometric parameters or I/O parameters.
Contents
