Iron losses computation on regions
Introduction
Iron losses computation on regions enables to compute modified Bertotti or LS iron losses on a selection of laminated regions. The iron losses model can be defined on the material or in the iron losses computation box in post-processing. The computation gives instantaneous losses and averaged losses over a period for a set of fixed geometric parameters or fixed I/O parameters
Contents
