Transient Magnetic line (3D) / point (2D) region
Introduction
The line (in 3D) / point (in 2D) regions are material regions used to model filiform regions in the study domain.
Material regions (filiform regions)
Filiform regions enable the modeling of regions of small cross-section.
The filiform regions are described in the same way as the massive regions; with in addition the cross-section of the region.
The following filiform region types are available for a 2D and 3D applications:
  • Magnetic * / in 3D
  • Coil conductor / in 2D
Note: * In 3D, the direction of the magnetic field for a magnetic region is imposed by Flux. The magnetic field is usually considered tangent to the line that models the filiform region.
