Steady State AC Magnetic volume (3D) / face (2D) region
Introduction
The volume (in 3D) / face (in 2D) regions are the material regions used to model the massive regions in the study domain.
Material regions (massive regions)
Material massive regions enable the modeling of the material media (with materials). The physical properties of the medium are those of the corresponding material region.
A massive region… enables the modeling… It is defined by…
air or vacuum of the air or of the vacuum
(predefined) (permeability μr =1)
magnetic non conducting
of a medium:
magnetic
non-conducting
a material with: permeability μr
solid conductor
of a medium:
magnetic or not
conducting
resistivity ρ
coil conductor
of a medium:
conducting with source
non-magnetic
a number of turns
an electric component
coil conductor with losses
of a medium:
non-magnetic
with losses computation
→ The two last medium represent a coil:
  • constituted of a number of turns
  • passed through by current
resistivity ρ
a number of strands in parallel
strands geometrical dimensions and orientation
Specific to 2D with current density
of a medium:
non-magnetic
a material with:
permeability μr
resistivity ρ
  A massive region … enables the modeling … It is defined by …
Specific to 3D Steady State AC Magnetic
solid conductor
described by surface impedance
characterized by: a very small skin depth with respect conductor sizes
of a medium:
magnetic
passive conductor
a material with:
permeability μr
resistivity ρ
In 3D, for solid conductor regions described by surface impedance, refer to section Surface impedance condition (3D).
