Abaqus Interface 2022.1 Release Notes
Altair HyperMesh
New Features
- Segments Selection and Manipulation
- Individual segments can be selected from idle. Organize, delete, and other advanced options are available.
- New User Comments Entity
- A new user comments entity is implemented which allows you to add comments of your choice to the input file for the main deck and include files.
Enhancements
- Redundant Entity Management for Sets
- Allows you to realize undefined sets referred by other entities when the undefined sets come from a secondary import such as include files.
- Legacy Comments Support
- Component and Property legacy comments support are available while exporting the input file.
- Consolidate for AutoContact
- Consolidation of detected contact/tie in an AutoContact search has been re-introduced.
- Model Check Validation
- Check enabled for elements with missing property assignment.
- Contact Pair Selection for Model Change
- While defining model change, selection of a contact pair is now allowed instead of main and secondary surface.
- New Keywords
- *JOULE HEAT FRACTION
- Updated Keywords
- ALLSECTIONPTS in *ELEMENT OUTPUT
- Post-Processing
- Abaqus 2022 ODB result file reading is supported for HyperView and HyperGraph.
Resolved Issues
- Multiple issues and application errors in Load step manager are resolved.
- An issue with order in which *BEAM GENERAL SECTION is written to the input file is resolved.
- Model checker issue for kinematic coupling is fixed.
- Model checker application error issue for zero length 1D elements is resolved.
- Segmentation error on updating DCOUP3D element dependent nodes is fixed.
- Tension cut-off value for *LOW DENSITY FOAM set to zero as default is fixed.
- Search is updated to find *FRAME SECTION.
Abaqus Interface
Enhancements
- Abaqus 2022 Reader
                            - HyperView now supports post-processing Abaqus 2022 ODB result files.
Resolved Issues
- Edge selection does not work while spherical clipping is on.
- Updating the pressure direction changes the magnitude of the pressure.
Altair HyperGraph
Enhancements
- Abaqus 2022 ODB result file reading is supported for HyperGraph.
