ADVC Interface 2022.1 Release Notes
Altair HyperMesh
New Features
- Card Support
                            - $UserMaterial
- To define your own material properties for calculating stress. Supported for Structure Analysis.
- $UserMaterialOfHeatTransfer
- To define your own material properties for calculating stress. Supported for Latent Heat Transfer Analysis.
- $MaterialUserLibrary
- Specifies the library file name of user function used in $UserMaterial and $UserMaterialOfHeatTransfer for heat transfer analysis. You can specify only one MaterialUserLibrary document in the analysis model. Both absolute and relative file paths are supported.
Enhancements
- "Allow 2D-3D set segmenent re-parenting" option is supported in . This option allows to select shell elements over solid elements during set creation
