OptiStruct Interface 2022.1 Release Notes
Altair HyperMesh
New Features
- Automatic method to define a free convection setup
                            - New bulk cards CONVG and CNVGADD added to define free convection and combined free convection, respectively.
- Subcase dependent free convection are defined with CONVG subcase selection cards.
- Free convection definition can be created from Solver Browser.
- CAFLUID-based flow heat transfer
                            - New element CAFLUID added as 1D element entity in Rod config.
- New property PAFLUID to define 1D CAFLUID heat flow element.
- CACONV bulk card added to group entity to define interface for forced convection heat transfer using CAFLUID.
- Adaptive Perfectly Matched Layer(APML) for exterior acoustics
                            - New element types CACPML3 and CACPML4 to define APML element with triangular and quadrilateral base, respectively.
- PACPML to define properties for APML elements.
- Pressure penetration load to simulate fluid penetrating through the surfaces on a contact interface
                            - New bulk card PRSPENE to define pressure penetration load.
- PRSPENE loads can created from Solver Browser.
- OptiStruct specific PRSPENE checks are added in model checker.
- Shell to Solid connection
                            - RSSCON1 bulk card added to define connection between shell and solid elements.
- RSSCON1 is mapped to group entity.
- SENSOR input to activate loads
                            - New bulk cards SENSOR to define sensor input.
- SENSRAD bulk card to defined union of several sensor inputs.
- Subcase references of SENSOR and SENSRAD are defined through SENSOR in subcase information entry.
- Modal damping as a tabular function of mode index
                            - New bulk card TABDMP2 to define modal damping as a tabular function.
- TABDMP2 card is mapped to curve entity.
- MEFFMASS output in HyperMesh set based format
- MEFFSET bulk card to group element sets to output MEFFMASS output in set based format.
- Fatigue process manager template
                            - Option to write all fatigue cards into an include file.
- Seam and Spot weld options are now enabled for EN fatigue method.
- FKM2 option for Seam and Spot weld.
- Import option to handle preserved nodes
- Section Property tool for VABS
                            - Generates VABS *dat file from intersection of plane with Shell composites.
- Updates 1D beam with PBEAML property using VABS *.dat file.
- Limited to OptiStruct interface.
- 1D meshing consolidation
- Consolidated 1D beam tools and Marine Stiffener meshing.
- Beam → Solid
- New tool to create Solids from 1D beam with standard beamsection.
Enhancements
- Pre-tension manager now allows CBUSH elements to define preload.
- JOINTG element enhanced to support newly added combination joints in OptiStruct.
- JOINTG element enhanced to grounded Joint input.
- MATFAT bulk card enhanced to include SNTBL continuation line for xy format inputs.
- Mechanism browser enhanced to include Set as an input in addition to component input.
- Multiple input selection for combined loads, for example: LOADADD, SPCADD, PTADD, and so on.
- PCONT bulk card enhanced to input Main/Secondary surface for Auto contact in OptiStruct Explicit analysis.
- SUPORT1 bulk card enhanced to input grid set.
- Free format (comma separated) export for individual include file export.
- MODCHG bulk card enhanced to input TIE contacts.
- Non-Linear transient analysis type enhanced to input CNTSTB, MOTNJG and LOADJG subcase selection inputs.
- PCONT bulk card enhanced to reference CLRNC bulk card.
- LOADJG subcase selection input for Linear static analysis.
- 3D visualization of taper beams- Limited to standard sections
 Figure 4.
- Beam → Surfaces- Create properties or nodal thickness on shell mesh created.
 Figure 5.
- Support for shell beamsections.
 Figure 6.
- Section Property tool for Elastic and Shells- Section property now uses Elastic section config instead of Generic sections.
- The tool can also generates shell beamsection with auto welds.
Resolved Issues
- Bead fraction response type selection as design constraint.
- Cannot change local coordinate system for pattern repetition in DTPL card.
- FE import reader crash caused by formatting of $HMNAME.
- Move TIE bulk card from Explicit analysis to Contact folder in Solver Browser.
- Application error while editing elements.
- Incorrect ply thickness update in Matrix Browser for PCOMPG.
- MAT9OR card name is now consistent with OptiStruct documentation.
- Incorrect import of CBEAM elements.
