ANSYS Interface 2022.1 Release Notes
Altair HyperMesh
Enhancements
  • Unblocked format supported in import for Materials, Real Block, Loads, Constraint equations, and Systems.
  • Blocked format support for import of Pressure Load and Temperature Load.
  • Contact surface migrated to set segment entity.
  • Embedded Entity Editor support for contacts, Loadsteps, and set segments.
ANSYS Interface
Resolved Issues
  • Edge selection does not work while spherical clipping is on.
  • Updating the pressure direction changes the magnitude of the pressure.
