Radioss Interface 2022.1 Release Notes
Altair HyperGraph
Post-processing Enhancements
- Corrected variable output names from /TH/CLUSTER.
- Support for new output variables VX, VY, VZ, SSP, and MACH for /TH/QUAD and /TH/BRICK.
- Support for new output variables from /TH/SLIPRING, /TH/RETRACTOR, /TH/SUBSET, and /TH/TRIA.
Resolved Issues
- /TH/SURF outputs selectable.
Altair HyperMesh
New Features
- New Constraints Entity
- The new Constraints entity is used for the definition of /MERGE/RBODY
                                keywords.
- New Systems Workflow
- The new Systems workflow provides a interactive and efficient user
                            experience for the creation of coordinate systems.
- Import of Compressed Input Decks
- It is now possible to directly import a compressed input deck.Only the format .gz is supported.
Enhancements
- Solver Profiles Cleanup
- Radioss profiles lower than 2017 are no longer exposed.
- Panels and Panel Functionality Removal in HyperWorks
- Panels or panel functionalities for which an equivalent tool or workflow exists in other areas of the product (example: Browsers, Graphical entity selection, ...) are removed from HyperWorks only.
- New Supported Keywords
- /ANIM/VECT/PCONT2
- Updated Keywords
- /ADYREL
- Migration of /ADMESH/SET to Set entity
- The keyword /ADMESH/SET, previously mapped to the Property entity, is now defined in the Set entity.
Resolved Issues
- Display orientation of /SKEW/MOV2 is corrected.
- Display orientation of /SKEW and /FRAME depending on the DIR value is corrected.
- /SENSOR/RWALL is now correctly written on export.
- Radioss /SET/GENERAL are maintained as in import/export as an unsupported keyword.
- /MAT/LEE_TARVER in now correctly written on export.
- Correction in Set assignment in /RBODY Entity Editor.
- Correction in /TABLE support.
- Correction in /TH keywords when reference entity is renumbered. The renumbered ID is now correctly updated in /TH keyword.
- Correction in export of /SURF/SEG when defined on 2nd order hexa elements.
