mdlIObject AddAttachment
Adds an attachment to definition type entities (System, Analysis, Template, or Assembly).
mdlIObject_handle AddAttachment new_handle, varname, label, attachment_type, attachment_tag
MotionView Tcl Modify
This command adds an attachment using the ‘varname’, ‘label’, and ‘attachment_type’ arguments. The 'label' and ‘varname’ are required attributes to create any entity (Point, Body, Marker, Joint, etc.). In case of an Attachment, you must also specify the type of entity (for example Point, Body ,or Vector) which will be used to attach to the other System.
- new_handle
 - The handle of the newly created attachment.
 - varname
 - The variable name of the attachment.
 - label
 - The label of the attachment.
 - attachment_type
 - The type of entity that can attach to the System/Assembly/Analysis.
 - attachment_tag
 - The tag for the attachment (the ’attachment_tag’ is basically a keyword which will be looked for in valid scope for an attachment candidate).
mySessionName GetProjectHandle myProjectName
set activePageNum [myProjectName GetActivePage]
myProjectName GetPageHandle myPageName $activePageNum
set activeWinNum [myPageName GetActiveWindow]
myPageName GetWindowHandle myWindowName $activeWinNum
myWindowName GetClientHandle myClientName
myClientName GetModelHandle myModelName
myModelName GetObjectHandle obj_handle
obj_handle AddAssembly assem_handle assem_0 "\"Assembly 0\""  <data file>
assem_handle AddAttachment attach_handle att_0 "\"Attachment 0\"" Point Tag_0;
assem_handle ReleaseHandle
attach_handle ReleaseHandle;
obj_handle ReleaseHandle;
myModelName ReleaseHandle
myClientName ReleaseHandle
myWindowName ReleaseHandle
myPageName ReleaseHandle
myProjectName ReleaseHandle
mySessionName ReleaseHandleErrors
Returns the handle of the newly created attachment if successful. If there is an error, an error code will be returned.
