mdlIObject InsertRecord
Deletes one or multiple table entries.
mdlIObject_handle InsertRecord idx
MotionView Tcl Modify
This command deletes one or multiple table entries. The table index gets updated once a particular table is inserted.
- idx
 - The index of the table to be deleted.
hwi OpenStack
mySessionName GetProjectHandle myProjectName
set activePageNum [myProjectName GetActivePage]
myProjectName GetPageHandle myPageName $activePageNum
set activeWinNum [myPageName GetActiveWindow]
myPageName GetWindowHandle myWindowName $activeWinNum
myWindowName GetClientHandle myClientName
myClientName GetModelHandle myModelName
myModelName GetChildHandle tab table_event
tab GetChildHandle hand tbl
hand InsertRecord 2;
myModelName Evaluate
hand ReleaseHandle
tab ReleaseHandle
myModelName ReleaseHandle
myClientName ReleaseHandle
myWindowName ReleaseHandle
myPageName ReleaseHandle
myProjectName ReleaseHandle
mySessionName ReleaseHandle
hwi CloseStackErrors
Returns 0 if successful, otherwise an error code.
