mdlIObject HighlightGraphic
Determines if a graphic under an object is highlighted or not.
mdlIObject_handle HighlightGraphic highlight_state
MotionView Tcl Query
This command determines if a graphic under an object is highlighted or not.
- highlight_state
- True
 - Graphics under an object are highlighted.
 - False
 - Graphics under an object are not highlighted.
To use this command there has to be a system defined in the model.
hwi OpenStack
mySessionName GetProjectHandle myProjectName
set activePageNum [myProjectName GetActivePage]
myProjectName GetPageHandle myPageName $activePageNum
set activeWinNum [myPageName GetActiveWindow]
myPageName GetWindowHandle myWindowName $activeWinNum
myWindowName GetClientHandle myClientName
myClientName GetModelHandle myModelName
myModelName BeginFlatListFastGet "graphic"
myModelName GetChildHandleByIdx myGraphicHandle 1
myGraphicHandle HighlightGraphic true;
myWindowName Draw
myGraphicHandle ReleaseHandle;
myModelName ReleaseHandle;
myClientName ReleaseHandle;
myWindowName ReleaseHandle;
myPageName ReleaseHandle;
myProjectName ReleaseHandle;
mySessionName ReleaseHandle;
hwi CloseStack;Errors
Returns nothing, a white border is drawn around the object to be highlighted.
