mdlIObject InterpretSet
Adds a new set statement to the system.
mdlIObject_handle InterpretSet keyword, tokens
MotionView Tcl Modify
This command adds a new set statement to the system. You must specify all tokens for the requested MDL set statement.
- keyword
 - The new entity's MDL statement keyword.
 - tokens
 - The remaining tokens for the corresponding MDL statement.
hwi OpenStack
mySessionName GetProjectHandle myProjectName
set activePageNum [myProjectName GetActivePage]
myProjectName GetPageHandle myPageName $activePageNum
set activeWinNum [myPageName GetActiveWindow]
myPageName GetWindowHandle myWindowName $activeWinNum
myWindowName GetClientHandle myClientName
myClientName GetModelHandle myModelName
myModelName InterpretEntity point_handle Point p_0 "\"My Point\" "
point_handle InterpretSet SetPoint p_0 "1+1" "2+2" "3+3"
point_handle ReleaseHandle
myModelName ReleaseHandle
myClientName ReleaseHandle
myWindowName ReleaseHandle
myPageName ReleaseHandle
myProjectName ReleaseHandle
mySessionName ReleaseHandle
hwi CloseStackErrors
Returns 0 if successful, otherwise an error code.
