mdlIObject GetLinkedSystemList
Gets the list of the systems which are linked to particular system. Linked systems can be either DATA or DEFINITION linked.
mdlIObject_handle GetLinkedSystemList type
MotionView Tcl Query
This command obtains the list of all the systems which are linked based on the type specified. If the type is DATA, then a list of systems which are linked by data will be returned. If the type is DEFINITION, then a list of systems which are linked by definition will be returned.
- type
 - The type can be either DATA or DEFINITION.
hwi OpenStack
mySessionName GetProjectHandle myProjectName
set activePageNum [myProjectName GetActivePage]
myProjectName GetPageHandle myPageName $activePageNum
set activeWinNum [myPageName GetActiveWindow]
myPageName GetWindowHandle myWindowName $activeWinNum
myWindowName GetClientHandle myClientName
myClientName GetModelHandle myModelName
myModelName AddSystemFromNewInlinedDef new_handle System sys_0 "\"SYSTEM 0\"" def_sys_1
myModelName AddSystemFromDefInMemory sys_handle sys_1 "\"SYSTEM 0\"" def_sys_1
sys_handle GetLinkedSystemList DEFINITION #It will return MODEL.sys_0
sys_handle ReleaseHandle
new_handle ReleaseHandle
myModelName ReleaseHandle
myClientName ReleaseHandle
myWindowName ReleaseHandle
myPageName ReleaseHandle
myProjectName ReleaseHandle
mySessionName ReleaseHandle
hwi CloseStackErrors
Returns the candidate list if successful.
