poI3DViewCtrl GetInputPrincipalPointOffset
Gets the input principal point offset of a stored view.
poI3DViewCtrl_handle GetInputPrincipalPointOffset name
HyperView Tcl Query
Returns a string consisting of an x and y offset. These values represent a shift of the view horizontally and vertically in the window. The values are typically the same as the manufacturer specifications of a camera.
- name
 - If specified, the offset of the view with that name will be returned. Otherwise, the current view’s offset will be returned.
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetViewControlHandle view_handle
view_handle GetInputPrincipalPointOffset "View 1"
hwi CloseStackErrors
Returns HW_InvalidHandle if the view handle is invalid.
Returns HW_InvalidArgs if the named view does not exist.
