poI3DViewCtrl RotateX
Rotates the contents of the current window about the X axis.
poI3DViewCtrl_handle RotateX angle
HyperView Tcl Modify
This command rotates the contents of the current window about the X axis.
- angle
 - Degrees of rotation.
Error
Returns 0 if successful, otherwise an error code.
